VC500 horizontal windlass hard no torque
JosefR
Sep 18, 2016
127
Catalina 30 Gulfport, Mississippi
Just noticed my title is wrong..."has no torque." I believe that is the windlass model that I have on my Catalina 30 from reading forums. When I have tried to use it, it will not pull the rode. It will rotate under power without a load. I am wondering if the motor needs to be serviced and if it is fixable. Looking for guidance on removing it and what might need to be fixed, if possible. I cannot look at it until this weekend.
Beneteau 323 Annapolis MD
There should be a socket on the drum end to tighten or loosen the clutch. Sounds like maybe yours is loose?
JosefR
Sep 18, 2016
127
I will take a look when I get there. Sounds too simple for a repair on MY boat!
Jan 4, 2006
7,647
So far, not so good.
Can you get to the motor and do a voltage check while the motor is under load to the point of almost stopping ? Maybe you're only looking at a corrosion problem with the cable contacts to the motor.
Still hoping to get you out of this without buying a new motor $ $ $ $ $.
Nov 6, 2006
10,215
Yup.. bad cable connections or a bad relay.. or (less likely) bad brushes in the motor..
With connections that bad, you probably will see some heat damage at the bad one.. disconnect power, clean 'em up and tighten; power side and ground side..
could be a binding gearbox that needs service and lube, but if I was a betting guy, I'd bet on a bad connection
JosefR
Sep 18, 2016
127
There is not. Only a slot for a screwdriver, I assume to remove the drum.
JosefR
Sep 18, 2016
127
No, it looks like I have to go in through the vberth, and I can't even get to that for a while. The stuff y'all said to look at is on the verge of being beyond me.
Jan 4, 2006
7,647
Take lots of close up pictures of all parts of the windlass (particularly the motor) next time you're at the boat and we'll show you what to do and where. It's what we do :biggrin:.
JosefR
Sep 18, 2016
127
I found there are two access plates in the locker, fore and aft. The aft one seems to go to the motor, which appears to be at some odd angle, but upside down on my belly, I couldn't even get my hand in the hole, much less see into it. Don't know if the berth access hole even goes to it.
