Variprop Pitch Adjustment on a Yanmar 4jh4hte
Sep 20, 2006
155
Hunter 49 Mystic CT
I have a Variprop 4 blade thats slightly over pitched (only gets to 2900 of a max 3200)
I've run it this way for a couple of years but I'm beginning to think that I'm not doing myself any favors here. So I want to adjust accordingly. Now the Yanmar specs say the rotation is counter clockwise when viewed from the stern. So is that a Left hand prop rotation?
Nov 6, 2006
10,242
I looked t the spec.. it says the engine is counterclockwise (left hand) .. the gearbox normally reverses direction so the prop should be right hand..
Sep 20, 2006
155
Hunter 49 Mystic CT
Thanks for the help. The gearbox is a Kanzaki KM4A2 So based on your comment I looked up the specs on this to be sure it did indeed reverse and it does. I didn't know they did that. Thank again
