Topping Lift "self destructed" , cheap alernative
Bob,When my topping lift was destroyed in a Noreaster a few years ago, I was on a mooring, and although I planned to haul the boat soon for the winter, I had no plans to drop the mast. As an alternative, I installed a "Boom Kicker" and a vang. In my case, the topping lift was just a static "keep the boom from falling with no sail up", in that it was just a wire cable from an eye on the masthead to an eye on the boom end.The only problem I got ennsared in, is that the gooseneck is mounted on a slide, with about 18" of motion, Prior owner used this for lifting the boom when the sail was furled and also when reefing. However, the Boom Kicker doesn't like the gooseneck being moved over too wide a range, as the boom end falls out of the darn slot. A real pain and a hazard when reefing in any condition, and extremely annoying under any adverse condition. My short term solution has been to keep the gooseneck position rigid, and move the sail to accomodate reefing. This, of course, restricts flexibility of the sail positioning.Bob
