I have C-310, sail no 307. The boat was built in 2005 and has in-mast furling. The leech of the main flaps or pulses when hard on the wind. I’ve tightened the leech line to the point where the leech is very slightly cupped, and that helped. However the problem persists. The last time I was out I put my hand on the end of the boom and put some pressure on it to pull it down slightly. The flapping stopped. So, it would seem the solution would be to add a but more vang, lowering the boom slightly, placing more tension on the leech. There is an issue doing that. Catalina installed vangs in later model C-310s with in-mast furling that don’t adjust. There is no vang control line. This was done to fix the boom angle to the mast to resolve issues with furling the main. However, the vang can be adjusted. There is a pin located mid-vang. Removed the pin, move the vang until the adjacent locking hole appears, then re-insert the pin.
Questions:
1. Have any C-310 owners with in-mast furling experienced the flapping leech issue?
2. Has anyone adjusted the boom down in an attempt to fix the issue?
3. Did moving the boom down make in-mast furling more difficult?
4. Does anyone know the spacing between the adjustment holes in the vang?
Cheers
Questions:
Cheers
