Rafi
For valve clearance adjustment on Yanmar 2GMF20: 1. which is cylinder 1 and which is 2?2. what is the best way to turn the crankshaft?3. after adjusting valves clearance on cylinder 1 at TDC mark, you need to turn the crankshaft 180 degrees to adjust cylinder 2. What is the indication you got there? Thanks
