Valve Adjustment
Feb 1, 2010
210
Hunter 33.5 El Dorado Lake, Kansas
Yes! You can get the Yanmar Shop manual part 2 and it will take you throw the process. I did this on my 2QM15F and what a deference this made. Also changed out the injectors. It ran like a new engine.
Nov 6, 2006
9,902
When you pull the valve cover to get access to the valve adjusting screws, the compression release mechanism comes with the cover.. so to answer your question , no it can't be done with the compression released.. You can turn the crankshaft slowly with a socket wrench .. be sure the fuel cut-off is pulled because a diesel can fire if it gets fuel while you are hand turning it.. could break an arm .. The procedure is in the GM manual, here on site in "General Downloads" Not a hard job but if you've not done it before, it would be good to get a gearheaded friend to watch/comment/handhold.. Good Luck..
