		Mark Johnson
Peggy:  I just bought a 460 with 2 Vacuflush heads.  I want to install a Y valve for direct discharge for offshore use.  The dealer claims that the vacuflush heads do not use enough water to flush waste up and over any kind of loop.  Is this true?  Do you have, or can you recomend a place where I can get a diagram and/or drawings to show the proper installation of Y valves for these heads?  ThanksMark JohnsonS/V Anthem
