I am in the process of replacing my water lines to the fresh water tank in the V berth of my 1991Hunter 35.5 for easier access. I removed the port forward side trim on top and both lower trims. The problem I am having is how to remove the front piece of wood of the V Berth that faces you as you that is about a foot wide and 18” high. I am attaching a picture for reference as there are no screw visible to remove. How is this attached ?
