V berth box drain
ami342
Oct 21, 2011
21
Oday 22 ft. Cocoa, Florida
Has anyone cut up a floor on a 1978 Oday 22 at the forward part of the Keel?
I'm trying to find a passageway from the watertank box under the V Berth to the lowest part of the bilge. After digging a hole thru the foam at the front of the bilge I run into a solid structure (under the compression post) and can't seem to find a way through. The reason I want a drain is if I ever have to drain my 10 gallon tank or mess up switching the blanking plug with the speed paddlewheel, there may be a substantial amount of water soaking under the floor and saturating the foam
