Using your outboard as an alternateur! or charger...
26
2 26S Montreal
Can anybody direct me to a thread on these forums if the topic has already been talked about.... I'm not sure how to go about this. I have a 9.9Hp and would like to know if I can hook it up to my batteries to charge them.... bit of a noob here
thanks
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Maybe
Some small outboards have an alternator, some don't. Read the owners manual and it should tell you. If it does, you should have a red and a black wire coming from under the flywheel, probably with some kind of plug. Alternator, if you have one, is small enough shouldn't need to worry about a regulator, and don't expect much charging from it. More than likely only puts out 3 to 5 amps if that much.
Dec 9, 2006
694
Oday 22 Hickory, NC
My 1985 Evinrude 9.9HP has a 6 amp alternator on it.
What is the brand and model number of your motor, we can tell you real quick if it has the alternator. I think most of the 9.9's did.
Jack
Mar 3, 2009
26
2 26S Montreal
It's 9.9 hp, 2006 Honda. Not sure about the make, picking it up tomorrow...
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
It will probably have a 6 or a 12 amp charging system depending on the model
Jan 10, 2009
590
PDQ 32 Deale, MD
Newb, perhaps, as in Eric Newby
thanks
Eric Newby, the writer of "A Brief Walk in the Hindu Cush" and other tales of novice adventure, is the origin of the word.
I my experience, outboards charge so little for sailors (limited hours and amps), it barely counts at all. Sorry.
Mar 6, 2008
1,498
I have a 9.9HP with alternator. I have it connected to 2 internal batteries with battery switch and they charge just fine with 2 or 3 hours of running the engine. If I do not get a chance to go out on the water for a month so that the batteries have a chance to charge, I plug in a $ 40.00 tricle charger that produces about 1 AMP at about 13.8 VDC for about 3 days and it is fully charged. My 9.9 has an electric starter but I never us it since it also has a pull cord.
So I think you can use your 9.9 to charge your batties just fine.
larryw
Jun 9, 2004
395
Beneteau OC400 Long Beach, CA
Charging batteries has two meanings; keep them at a charge level so they won't die, and charging them up after a night of lights, stereo, TV, etc. An outboard won't do the latter, it just doesn't have the beans. Do you want to sit on a mooring or at anchor with your outboard running for 3 hours evey afternoon on a four or five day trip? Your anchoring or mooring mates wouldn't. Get a Honda 1000 genny instead. One hour a day running a quiet generator.
Jun 7, 2007
875
Pearson- 323- Mobile,Al
add a battery and charge at the dock. But hooking up the outboard should help a little. I usually end up motoring an hour or two a day while cruising. Finding an anchorage or going to a marina ...through a narrow spot so you can pick up a few amp hours just by incidental motoring. But unless you motor a lot it won't keep your batteries charged.
Beneteau 323 Annapolis MD
Guy, there was a thread started on the 19th if you go back to the Ask All Sailors page. You'll notice Joe hooked up a 13.8 charger to do his charging.
Also not wanting to rain on your parade, but outboards I've seen have only a 12-volt output (at your ? amps in this case). You can't charge at that voltage unless your batteries are less than that. Even my Honda 2000 generator only puts out 12 volts- barely a maintenance charge.
Jun 7, 2007
875
Ron you might want to check the actual DC voltage. I would bet that it is close to 14.4 volts as they recommend that the output only be used for battery charging. It appears that the DC voltage is not regulated on some models and could overheat your battery. Again I suggest that you use a volt meter to check exactly how many volts the honda is putting out.
larryw
Jun 9, 2004
395
When I said to to get a Honda 1000, I assumed you had a shorepower plug. That's where you'd plug in a generator. The gen puts out 120 v. to the built-in charger. If you don't, disregard that, then. I've seen guys hook small engines to externally regulated automotive alternators, mount the whole thing on a piece of plywood. Puts out 60-80 amps, take an hour to charge up.
MrBee
Dec 30, 2008
425
Irwin 34 Citation Middle River, Md.
Not every boat needs 200amp hours per minute....
The output should be fine for the boat you have, unless you have a few computers on there.
Bee
Mar 3, 2009
26
2 26S Montreal
Thanks for all the info... I'll have to get out there and see what my consumption is like... Probably not that much after all... Running lights, cabin lights (4) at the most and Nav aids... Depth finder, auto-tiller, speed indicator, compass light. I have two batteries and charging them now. I think I should be good for weekend expeditions.
regards
