C
carisea
I bought a used passage 42 that came with an asym spinnaker and a dousing sock. I have pretty much figured out how to set up the halyard, sheets and downhaul based on all the parts that came with the sail. My problem is associated with the dousing sock. As it is presently rigged there are 2 short lines attached to the hoop. They are attached at the same two connection points on the hoop. At the midpoint of these lines a thin line running in its own dedicated pocket is attached to each of the lines.It would appear as though I should untie one of the two thin lines from the short lines and use it to haul the sock up. It would also appear that I am missing a long thin line to pull the sock back down from the top of the mast. I have went on different web pages but cannot seem to find any diagram related to the sock. Thanks
