using starboard to replace a teak bulkhead
1
catalina 25 stockton
I need to replace the port side bulkhead on a Catalina 25. Currently it is a teak plywood. Teak plywood is hard to find in my area, outside the area it is available but shipping costs as much as the teak. I do have a local source for Starboard. I have used it before on boats but not in a structural application like this. Anybody used it in a bulkhead application? I know more newer boats are using Starboard instead of teak but on a bulkhead where the chain plate will connect? Will it be structurally sound? This bulkhead will be 4'x4' by 1/2 inch. Thanks LD
Jim
May 21, 2007
775
Catalina 36 MK II NJ
ARe you talking about the white plastic stuff? That is a good question. I am not a structural or material engineer.
Tim R.
May 27, 2004
3,626
The size and thickness of starboard you would need to equal the structural integrity of the same size plywood is likely to be more expensive than the marine ply. It also will move more than plywood which is not good for structural applications.
Feb 6, 1998
11,709
Starboard..
King Starboard or any of it's imitators is not a structural product! Besides that almost nothing will stick to it so tabbing in a bulkhead is nearly impossible.
If you can't get teak ply any marine grade or high quality exterior grade (no void) plywood will work. A new sheet of teak ply won't match your existing bulkhead anyway without some serious time in the stain/color matching department.
You can always paint the bulkheads white and go for the Hereshoff look.
Starboard is basically a decorative product, and a great one, but should be reserved for applications where it is not under load or stress. You can bend a sheet of 3/4" Starboard very, very easily while a sheet of multi-ply high quality plywood is very, very stiff by comparison.
I had to add those stainless struts to my pedestal guard table as even the weight of my instruments, on that short span, was bending it.. Imagine a span 6+ feet!!!
Dec 2, 1999
15,184
LD:
What is your purpose for wanting to use polyboard vs. plywood? If it is because you want a white finish, you should consider a exterior grade plywood with formica on the visible side.
As
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Starboard is not a structural material and they say as much in their own literature. It isn't stiff enough to work as a bulkhead. Also, Maine Sail's point about almost nothing sticking to it with any real degree of success is a very valid one. It is also quite heavy and expensive.
IMHO, you'd be far better off making the bulkhead out of marine plywood.
If you want something lighter you can always make the bulkhead out of high-density rigid foam, like Divinylcell and glass, by laminating a big flat sheet of it and then cutting it to fit. This might be easier to do than making the bulkhead out of plywood, since you could put the foam up and cut it to size far more easily than you could the plywood, then lay it out flat and laminate the fiberglass to it.
Tim R.
May 27, 2004
3,626
Related question: Can you fit a piece of anything that measures 4x4 through your companionway? I can only get something about 30" through mine.
Ross
Jun 15, 2004
14,693
When I needed to make a new bulkhead for Bietzpadlin I prepared 1x12 cypress and laid the boards out on a table, marked the shape. and cut it out . Then I carried one plank at a time up and fitted it into place. When I was satisfied I edge glued the boards and fastened battens across the width with screws.
Jun 1, 2005
772
Pearson 303 Robinhood, ME
Go to a place that does miillwork and or stair parts. They can find and/or order some teak plywood for you. I usually go into places like that if a have small projects... theres always stuff kicking around that they will give you. If they know you are looking for something... they can trow it in the corner for you.
Ix-nay on the Starboard... do it right.
Dec 4, 2006
279
Hunter 34 Havre de Grace
Plywood
I'd use marine plywood.
If I wanted it to look like teak, then I'd cover the visible area in veneer.
That would also let you make the bulkhead in two pieces if getting a 4x4 piece through the companionway is a problem.
I think if you look back a few months in the archive someone posted a good source for the veneer.
Oct 22, 2008
3,502
I'd second Boulter Plywood, but I might be a bit biased, since it is only about 20 minutes from where I am. :)
Jun 9, 2008
1,801
- -- -Bayfield
Starboard is not a good choice for a bulkhead. Marine plywood is your best choice and of course, to match the rest of the wood, you want teak. Marine plywood has waterproof glues superior to other grades of plywood. Exterior plywood used in houses is not a good choice (and you can't get it with a teak veneer). Regular plywood is not a good idea at all. Bulkheads are usually "tabbed" with fiberglass to the hull and possibly elsewhere. You cannot attach fiberglass to starboard plastic. When you do fiberglass your marine teak plywood, you want to remove the teak veneer at the edges so that you fiberglass the underlying surface for best adhesion. Don't use Starboard. It sounds like you are looking for an easy fix to a integral and structural part of your boat. You don't want to cut corners with this sort of repair.
