I am asking all sailors whether, or not it is a valid idea to use stainless hardware below the waterline. Let me explain the projects:
1) Mounting seacocks. Seacocks are Marelon bedded onto the hull, have fiberglass backing plates epoxied to the hull, and the bolt heads are intended to be resessed into the hull, filled, and faired.
2) Mounting my fiberglass rudder gudgeons. Gudgeons are fiberglass, hull is fiberglass, bolts will be bedded into both, but have epoxy around heads and nuts. Possibly faired.
The boat will remain in fresh water for the next 20+ years, but will return to the open oceans someday. My alternative is to use bronze bolts, such as the ones that came with the boat.
Thanks for the feedback,
T.
T.
