Using outboard on a 26'
N
Newbie
I am looking at a 1997 Hunter 26. It has a 9.9 engine with the forward and reverse control in the front. My question is, how do you manuver that boat with the motor sitting so low that you lose all visibiity? I would be using a very busy marina requiring a lot of jockeying around before you can get to the ramp/dock. I know I can extend the throttle but how do you go about extending the foward /reverse controls.
Hunter 26 Illinois
Add a remote
I don't know how you do it either, other than adding a remote. I got lucky, 4 days after I brought our, new to us, boat home the 9.9 Honda was stolen off the back of the boat. These guys were pros, they had wrenches and because I backed the boat to the end of the driveway, due to the drop off, the motor was 7 feet off the ground. Anyway, the insurance company and I bought a new motor with a remote and it works great.
Depending on the motor, you may be able to buy a remote for it.
MikeH
Jan 7, 2004
157
Hunter 260 Perrysburg, OH
It is definitely not fun, that's for sure. I dock in a small boat club on a river that often has a 1-2 knot current. I don't have remote controls or my rudder tied to my motor.
When I'm docking, or leaving, I leave the rudder up and out of the water and motor strictly with the outboard. I have my left foot down in the well with the motor, and with my 5' 9" height I'm able to see enough to maneuver properly. I thought about remote controls, but my docking and leaving time is so minimal versus sailing time the clutter of extra controls isn't worth it to me.
45
- - Florida
First of all do yourself a favor and get a remote. The cost is so worth it (and it isn't that much). It makes all the difference in the world. Combine that with connecting the motor and the rudder. I promise you you will be happy -- or at least as happier.
Bart Ford
controls
When I saw this article that appeared in Sail magazine September of 2009, I saw a remedy to a problem that has plauged me since I bought the boat.
Finally a way to do forward/reverse/neutral without bending over.
I have adapted what he did and used much of the same ideas. I used the end of a old lifeline. It had a t-bolt with a threaded rod coming out. the threaded part is 1/4-28 left hand. Nothing you can find with match to that EXCEPT a screen door tensioner. Used the aluminum coupling nut and the rod. Bought 1/4-28 Right hand die nut to thread with, only because I had a handle that would work and it was threaded to 1/4-28.
Used aluminum pipe that was already formed for the support. Works great.
The bracket from the lifeline was more like a yoke. I used a SS 1/4-20 bolt and nylon lock nut, 2 nylon washers,one on either side of the shifter. I tried it both ways. Off the side and felt like it was too much stress on the part, over it with the shifter in the middle was better.
I have less than $10 in the whole affair, includes the die nut. I have really used my Dremel Tool in this thing. If you need a source for cheap dremel bits, try www.widgetsupply.com
Jun 4, 2004
109
Hunter 38 Pentwater MI
Try a Mercury motor - they have the throttle and forward/reverse in the handle. I stand next to the motor in the well -hold the tiller with my left hand and the throttle pointing up in my right hand -Never turn the outboard to steer and only use the handle for forward and reverse - stop with reverse when docked. Been docking this way since 1998 and it is relatively easy.
