what is the proper way to determine the output in amps, or ah from a solar panel when attached to a battery?
I'm trying to compare 2 panels, one outputs 24 volts, but is rated at 5w, the other outputs 19v, but it rated at 12w.
I can check the volts easy enough and sure enough the 5w panel outputs higher voltage, but how do I test the amperage output to see how much I am actually putting into the batteries?
