I was coming out of the Haulover Canal today into the 90 degree turn, which is very wide with plenty of room, and a sailboat was coming the other way. I kept edging over to starboard for a standard pass but he kept moving over as well. At the last minute, I realized that he was going to push me right into the green day beacons so I quickly cut across his bow and the short cut across the wide corner of the channel. I then could see him and realized that he had his head down buried in his GPS and was trying to trace the magenta "Recommended Route" line on the chartplotter around the turn. It goes right around the outside of the turn.
He never even saw me.
On the other side of the bell curve, I was heading into anchor at a likely looking spot I found on the chart just before New Smyrna Beach. This bird is standing on that spot ("x" on the chartlet):
I noticed something slightly different about the wave pattern ahead. You can almost see it in the photo. I did a quick "U" turn and then had the idea of just continuing around in about three 360 degree turns. This set up a bunch of waves and, when they went over the shoal, I could clearly see that there was very little water there.
I anchored a little closer to the channel than I planned and saw the birds walking along the shoal a few minutes later. It now extends from the day marker all the way to the point. Lat / Long provided in the lower right corner for anyone passing this way.
