Buyer Beware! Remember, a used sail is just that. The previous owner got rid of it for a reason. While there are some decent sails to be had, there are some thing you should be aware of.With Mains, unless it comes from a similar boat, the sail may need some rework to get it to fit your boat. The slides on both the luff and foot may need to be changed out, the sail may be to short on the foot and luff, leaving you with less sail area. On the converse, if you need to have it cut down, there is another expense. Also, the reefs may not line up with your reef blocks, if yours are mounted on the side of the boom.And last, you will still have a used sail, which may not last as long as you hope. If you are expecting to keep your boat for awhile, check out the Doyle sails in the chandlery on this site. Even if you plan to sell the boat in a couple years, a newer sail will help the resale.
