USCG Raises Assumed Average Weight per Person:
134
Bristol 30 Long Island Sound
In this season of expanding waistlines, even the Coast Guard has been forced to monitor midsections: specifically, the drafts of passenger vessels burdened with transporting an increasingly heavy population.
The Coast Guard in December formally put into effect rules requiring certain passenger vessels to comply with its new Assumed Average Weight per Person. That new weight, 185 pounds, is a full 25 pounds more than the previous average, 160, a figure put in place about half a century ago — after French fries were invented but before billions and billions had been served.
“Are people bigger now?” said Mark Cedergreen, who began running a charter sport fishing boat out of Westport, Wash., in the 1970s, when the salmon population was healthier and people apparently were, too. “Yes.”
And so vessel operators across the country have faced a reckoning: shed weight, and potentially revenue, by reducing the number of passengers they carry, or find a way to keep squeezing people on without falling out of compliance with the Coast Guard.
New York Times
http://www.nytimes.com/2012/01/02/u...ssumed-average-weight-per-person.html?_r=1&hp
KD3PC
1,069
boatless rainbow Callao, VA
While a great move, I am not sure that given the quoted sizes the media describes (male 191, female 165 from most recent CDC data - 2002) that they should not have just gone to
200lbs.....
more realistic.
Sep 5, 2007
689
MacGregor 26X Rochester
Mathematically, that works out to 3-1/3 men for every woman on a boat loaded to the new standard. I guess they expect more men than women to sail on a given excursion.
I'm afraid I've got the average male's weight beat by better than 35 lb, much to my family's dismay. And I don't even look big. :redface:
caguy
Sep 22, 2006
4,004
Thank you CG, that was a giant leap to becoming closer to normal. :D
Mar 8, 2011
296
Ranger 33 Norfolk
This is sad and "LoL" at the same time. . .
I work with designers who engineer commercial buildings. I've joked about people getting heavier before, and when the building code will change to reflect this. . .but if you break down the loading it isn't as funny. . .
Floor load per square foot is calculated from Dead Load (weight of structure) + Live Load (people, things, extra) and as people are getting heavier the "extra" part of the equation is getting smaller :doh: Not enough to go screaming from the hills, but it is there.
Funny story (well, not really I guess), one of the jobs we had involved a renovated second floor that was turned into a cardio studio for overweight people. We got the job to fix it when part of the floor collapsed :eek: No one was hurt.
May 24, 2004
7,230
CC 30 South Florida
Be careful law enforcement will follow the new guidelines as far as how many people rather than the actual weight of the people aboard. Does it make sense? You may put in a lot of weight in boating and convenience accessories but only so many persons. Legislating common sense is a profitable undertaking.
Jun 2, 2004
3,673
Makes no Difference for Enforcement
The capacity plate reads persons or equipment and gives a weight. If you exceed that limit in either persons or equipment you may be cited. In other words, your plate reads 3 persons or 900 pounds you put 3 300 pound persons on board you are fully loaded and if one of those guys brings a cooler you can be cited. Conversely if you put 4 people on board who weigh a total of 600 pounds and a 20 pound cooler you may still be cited as you exceeded the 3 Persons.
Will make no difference for most of us here anyway as sailboats are not required to display a capacity plate. A few do and I suspect that the way the regulations are written if there is a plate you must abide by that capacity.
Jun 6, 2006
6,990
it will effect new boat owners as they did not change the density of water. so a boat that previously held 4 people might now only legally hold 3. course you would probably know that before you bought the thing but it would figure into the decision to buy.
Nov 23, 2011
21
Blue Gallion 235 Driveway :(
I love how the gooberment keeps telling people to stay away from meats and eat more 'whole grain' foods. Then a gooberment agency talks about how they have to adapt to people getting fatter.
But they forget to mention that eating any plant matter even 'whole grain' still raises your glucose levels and insulin response causing your body to store more fat than it would if you ate more red and lean meats.
Hypocritical lies.
Feb 22, 2004
222
Hunter H340 Michigan City
As I see it, it is a safety issue. An overloaded boat for what ever reason is unstable and unsafe. Thank God the Coast Guard is being sensible about safety. Just look around at how many FAT people there are.
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
Begs the question ...
are manufacturers going to change their plates and advertising? For instance, MacGregor has a safety decal on their 26' boat that limits capacity to 6 people / 960 lbs. or 4 people / 640 lbs. without water ballast. (They advertise berths for 6 people). With these new regulations, will they now reduce their stated capacity to 5 people / 960 lbs or continue to pretend the boat is stable for 6 people?
38
Ericson 34 Lk Champlain
A few years ago a tour boat on Lk George in NY capsized and twenty people drowned primarily because the boat was loaded based on the old standard. The boat was turning and was hit by a wake, and that was all she wrote.
JohnS
177
Islander (Wayfarer/McGlasson) 32 St Georges Harbor
The water taxi capsize near Baltimore's Inner Harbor that killed 5 people back in 2004 was determined by the NTSB to be partly caused by the out-of-date average passenger weight standard.
