Upgrading to U-Bolts
115
Newport MKIi 30' Channel Is. CA
I have just ordered the U-bolt kit, for the shrouds, an am wondering if anyone knows any of the pit falls
Questions that come to mind
Will I have to remove the cabinet on the port side?
Can it be done in one day?
Should I use the old holes to save the extra day filling the holes and having the mast compromised while it dries?
Is Marinetex the filler of choice?
Thanks Buzz
Shell
Sep 26, 2007
138
Catalina 30 standard JC/NYC
Do one shroud at a time. Clean and seal the holes and let dry.
You can also use a halyard to help balance the mast.
Why are you changing the U bolts? Most failures are fatigue from the wire rope of the shrouds. Good luck.
Apr 18, 2009
115
The shrouds are ok but I am seeing "some" wavyness inside the cabin near the bolts and nuts I was going to just plate it but the cost is about the same. and I gain some space on my turnbuckles
Thanks for your response
