So I've been reading a while, had my Hunter 40.5 just over a month and I've been going through it making changes and writing up lists of future work.
This is all new to me as its the first boat I've owned so I apologise for any naivety in advance.
I have the original jabsco's in there and I recently did an overhaul on them both using the maintenance kit available online.
The aft head is not fantastic in all honesty, it doesn't drain 100% (it pumps out and then re-fills ever so slightly - is this normal?). I've also noticed that theres a slight leak which pools just behind the back of the basin. I've not had chance to investigate this further yet.
So I was looking at
http://shop.sailboatowners.com/detail.htm?group=1357&cat=1002
and wondering what are the advantages of upgrading to this system as a whole? I've seen Peggy mention the quality of jabsco which worries me.
Id also like to utilise freshwater when flushing, the hunter has a lot of water on board and I don't see a problem with sacrificing some to eliminate odours etc. My questions on this side is
Do I need to separate a water tank for this purpose or can I just plumb it straight into my system ?
Has anyone made this conversion?
Finally, the boat is 16 years old, the PO is not sure what's been done and what hasn't - where is the best place for me to start inspecting hoses and overhauling / replacing where necessary.
Thanks in advance
Redunc
So I was looking at
Thanks in advance
Redunc
