UPDATE....The old tank is out.. Large rust out hole in the bottom. I removed the sink to get access. The new tank arrived.. Aluminum and stainless and is a cube. Currently changing the plumbing. Here in Maine we need to treat for freezing. RV antifreeze is the preferred route. Old tank would get drained. The inlet and outlet lines would need to be released from the barbs ( always good for cuts and bruises) and then hooked together. Closing this loop, RV antifreeze is then run through all water lines. NOW the hoses will stay in place. A by-pass manifold with 3 ball valves will allow the same activity by simply turning valves..
