Some of you know that I have been doing extensive work on my 1973 O'Day 22, "Cassidy". I have a blog dedicated to the restoration (link below) that I have just updated after a four month hiatus. Anyway, I know that some of you are interested in repairs/restoration work similar to what I am doing, so you might want to check it out. I am open to your feedback and can even fill you in on some important "lessons learned" on this project.A couple of quick questions for the gallery:1)Anyone know where I can find four wire deck connectors (like the Perko fittings), I can easily locate the two wire connectors but I would like to combine the masthead and steaming light wires into one connector. 2)Has anyone installed a topping lift on an O'Day 22 or similar boat? I know that I will need to drill a new hole in the masthead and install a pin and block. I am wondering how people have rigged this so that the line does not interfere with the main halyard, chafe the sail or interfere with the boom end/outhaul.Thanks in advance! This forum is such a wonderful resource!Cheers,Josh
