I have not filled my water tank yet, since winterization.
I'm on my mooring and wanted to run the engine to charge the bat.
It ran hour or so, and I shut it off. I then heard water running, so I started to investigate. The head sink was overflowing on the floor. I had left the water faucets on and the drain cock was closed from winterization.
Hot pink water was coming out of the faucet! When I winterized, I drained the main and HW tank, bypassed it and ran polypropylene glycol through the system and out each faucet. I had then removed the shunt and replaced the lines so I would not forget next spring.
Running the engine had apparently expanded the remaining polypropylene glycol in the system and forced it out the open sink faucet. I was surprised about the volume, ~1.5 gal. At first I thought that maybe the heat exchanger had ruptured and what was coming out was ethylene glycol, but no loss of engine coolant put a relieved rest to that theory. Anyway seems like anything can happen on a boat.
