Unsubscribing From Sailboatowners.com
F
Frank
Having checked in several times with the same name and email address an accumulation of subscriptions has taken place. I sent a request email to the contact address and haven't heard from anyone. Certainly would like to remove all history from sailboatowners.com. Any other sailors with the same problem and possible solution? Thanks for your input. Frank
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
Unsubscribe requests
We handle all unsubscribe requests the same day. Please send your email address to phil@sailboatowners.com and also, please be sure any mail I send back to you will not be filtered. Thanks! ph.
M. E.
Unsubscribe
The unsubscribe process is automated. To unsubscribe an email address from one of the sailboat.com listserves you must send the "OFF" message. This and only this will unsubscribe you from the list. You must send the email from the email address you want unsubscribed. If you send the message from an email address that is not subscribed to the list, the message will be ignored. As an example, to remove your name from this list, send an email to: BeneteauSailboatOwners-OFF@lists.sailboatowners.com Nothing in particular has to be in the body of the email, the message itself unsubscribes the email address from the list. Each individual list (Beneteau Owners, Hunter Owners, Catalina Owners, etc.) has its own OFF address, so make sure you use the right one.
