Hey, thanks for asking, I should have tried to be more specific, but I'm always fighting the dreaded verbose monster. When centering the mast, yea, run the tape measure all the way up to the top, tie the end to a halyard. That way it's very acruate as the steel won't stretch like a halyard will. As far as where to on the other end, it works well to measure the toe rail coming back from the anchor up front, and make a mark perpendicular to the mast (right in line with the spreaders) then mark every couple of feet for about, say, ten feet. There's a point where you loose acuracy the further back you go, and you can measure to the toe rail going forward, but the tape ends up wrapping around the mast and it looses acruacy. You can re-launch the tape with a spin halyard and measure to the toe rail forward of the spreaders, but it's kinda redundant. When I start out, everything is hand tight, then I put on about 1/4 full tension on one upper shroud, then put on 1/4 tension on other, which adds up to half of full. Then I hand tighten the forward and aft lower shrouds watching the twisting in the mast. Which, looking for twist is easy once someone shows you, place your head next to the mast looking up and close the outside eye, using the one right next to the mast. Looks from the side to see forward and aft twists, look from forward and aft to see twists along that axis.
Also, to answer what I was talking about with moving the mast forward and aft, all this does is control weatherhelm. It is sometimes a trick to get the weatherhelm just right and end up with a forestay that is as tight as needed. As far as I know, there's no real tuning with the backstay, unless you're adjusting it while underway with block n tackle or hydrolics. If you've got that type of rig, then it kinda negates tuning the forestay. But, back to moving the mast. If you move your keel step all the way forward, and adjust your headstay turnbuckle all the way tight and have only minimun on the backstay turnbuckle, then you should have reverse weatherhelm. This means that when beating to wind, the helm will want to constantly turn so that the bow ends up going down wind. Moving the mast all the way back, will cause weatherhelm which is what we want, but probably too much which would cause the boat to want to constantly round up and tack. This is an incredibly slow thing, to have the rudder being dragged thru the water sideways. Somewhere in the middle is what is needed, so that the helm is mostly neutral, just a slight bit of weatherhelm. I find that the perfect amount for me on the H37C, is (and I can do this now because most everything is new in the steering department whereas if you have friction and the wheel doesn't turn freely, it'll be tougher ) is to have everything trimmed and set, then let go of the wheel, and it should track straight for at least a couple of 4 to 6 waves, depending on the conditions of course. You can really feel the weatherhelm and reverse-weatherhelm really well with a tiller boat. All the aqua engineers say that it's best to have just a tiny bit of weatherhelm because it helps with forces being applied and involved with the keel and the other aero/aqua dynamics. Backtracking here a second, the other thing to of course thing of when moving the mast fore and aft, is getting it to fit thru the cabin top and not bang against the inside of the hole wallering things out. Without the collar that we have, there's shims and rubber collars, but for ours, I'm still engineering what I think will work well. I'm open on ideas. I've used one of those rubber/plastic stair step collars and slid that one prior to stepping the mast. Some say, you can't stop the rain from coming down so feel comfortable having it minimalized, and I can see this with driving rain being forced into the top and at other openings. But, I know that with our collar, with everything being bolted well, it not only strengthens the mast, but the cabin top as well. There's old blogs of the first h37c's having problems with the top oil-canning.
Well, I think the verbose monster hit again, hope this helps,
Kb
s/v Renasci
