I've been following the diagrams...
in my Westerbeke owners manual, and I checked all of the connections. Except for the connection to the water pump, everything looked fine. The heat sensor (that displays water temp.) slid off of the terminal. Interesting to note that, after following the schematic, this sensor is part of the wire that goes to the starter switch. Funny thing is, when I left it disconnected, the engine started up just fine. I don't believe I have a fuse problem because, when the fuse goes, it won't start until you replace it (been there done that just not with this boat). I've "re adjusted" the wiring harness with ties (because I think it gets caught up on the stairway box whenever I open and close the engine compartment). I'll need to figure out how to keep that sensor attached (it slips off when the engine is running)...Unfortuately, I don't think Westerbeke has a replacement (unless I buy the whole electrical wiring harness which I don't want to do at this point). Let's see what happens in the next 2 weeks (I'm pulling the boat on Oct. 6)...Thanks for the responses, and feel free to chime in if you have any other insights.
