I am desperate to find a marine mechanic who is familiar with Universal Engines on the south shore (Nassau County) of Long Island. The mechanic who I was using did a poor job on diagnosing a problem on my 89 Universal M25XP. He reccomended a re-build due to white smoke coming out of my exhaust. He declined to do the job, but suggested I find someone who does a lot of work on Universals. That advise put me in touch with Hansen Marine in Marblehead, MA and when I described my problem they told me they highly doubted it needed a re-build. The first question they asked was; it is hard to start? When I indicated it has never failed to turn over in three years on the first attempt they said it could not be a compression problem. When I described the white smoke they immediately suggested mixing elbow. I have since had two overheats which somehow self correct. I have replaced every part of the cooling system over last winter, and I know the thermostat, cooling hoses and heat exchanger are in perfect condition. I have cleaned out the raw water filter, never finding anything that would cause a blockage. The raw water pump is brand new, and I have had the fresh water pump pulled out and checked as well. I have canceled my vacation using the boat, and my wife is afraid to take any trips that might require any motoring other than getting out of the slip and through the inlet. I cannot find anyone who will come down to the boat, and motoring to their location is out of the question. The boat is located in Point Lookout, and if anyone can suggest a good mechanic I would be grateful. I do not want to pull the boat for the winter, replace the mixing elbow, muffler and exhaust hose only to find out in the spring that that was not the cause of the white smoke and occassional overheats. I really have reached the desperation point. If the engine requires a re-build fine, I will then explore my options; repair or replace. I do find it hard to believe that a diesel with 850 hours does require a re-build. Just the fact of not knowing is driving me crazy.
