It's the coolant pump, part of the engine. Should be available from Kubota at a fraction of the cost from westerbeke. Over 400usd. Plus I'm in Malaysia getting it here will be another 200. The bearing has gone out, I starting to look for someone to make the bearing, it to be cheaper.Kubota would not know about that pump because it was put there by Universal (Westerbeke) They bought the pump from someone like Johnson (may be a different vendor) so you should be able to find a manufacturer's mark and a model number somewhere on it.. These can be rebuilt (usually, but not always,depending on damage) without too much pain. A new pump is pretty expensive.. Good Luck
The store on this site has some seawater pumps, so Phil may be able to pitch in here.
I have a spare saltwater pump.Kubota would not know about that pump because it was put there by Universal (Westerbeke) They bought the pump from someone like Johnson (may be a different vendor) so you should be able to find a manufacturer's mark and a model number somewhere on it.. These can be rebuilt (usually, but not always,depending on damage) without too much pain. A new pump is pretty expensive.. Good Luck
Yes they have a pump. About $400 plus another $200 to get it to. Me. I'm in Malaysia and hope to get one from the local Kubota dealer About $60.00Have you tried Westerbeke Corp they are the universal dealer now
