Universal M25XP motor mounts
J. Ford
Has anyone replaced the motor mounts on the Universal M25XP on a C30? How difficult is the job and did it help eliminate severe vibration?
M25XP Motor Mounts
J The related link goes to the C34 message board. You could also try the main C34 site, through the links from the board, and search for motor mounts. Our owners have had a variety of experinces with the Vetus mounts. Good luck, Stu
Tom Soko
What kind of vibration?
J, What vibration are you talking about? Vibration at very low RPM's won't go away with any kind of motor mounts. In fact, by changing to a slightly softer mount, vibration at low RPM's will increase. If you have vibrations at higher RPM's, there is another problem that needs to be addressed. In neutral? In gear? Need more info.
