So, over the last 10 years of owning my O'day 35 with a venerable Universal M25 Diesel, I have compiled the following list of spare part numbers. I hope this helps others track down the pieces they may need. If you see a part that I am missing (or any errors), please let me know and I will update the list. I have this available in word format as well and if you would like a copy, just PM me.
Dan
Items listed with ** are versions that I have had particular success with.
Universal M-25 or Kubota D-850 (used in the B7100 tractor) (D-950 is the same as the M25XP)
Cooling System:
-Oberdorfer N202M-15 pump:
--Oberdorfer Impeller no. 295628
--Cover gasket no. 295626
--Replacement O ring from Moyer Marine CSOB_06_67
-Antifreeze: Extended Life, 1.5 gallons with Water Heater
-Thermostat: Universal 303158 or Kubota 19203-73010 or 73014
-Radiator Cap: **Stant 10229 Radiator Cap - 13 PSI
Pencil Zinc
-3 inch exchanger (3/8 thread, ½ inch diameter up to 2 inch length.)
-For 2 inch exchanger Universal Stock number is 301068 (3/8 thread, .5 inch diameter,
1.5 inch length)
Glow Plugs: Universal 299685, NGK Y103K
Oil System:
-4.1 Quarts of Oil SAE 30 or 10w30, Diesel Oil CG-4 (do not use obsolete S, CD or CE)
-Oil Filter:20mm x 1.5 thread size (similar to 2004 Chrysler Sebring)
--Universal 300309 or 209
--**K&N HP-1004 Performance Wrench-Off Oil Filter
--Purolator PER-4620
--Kubota 70000-15241
--Fram PH-3593-A (replaces PH 2849A)
--Motorcraft FL-799
--AC PF-57
--Lee LF-2808
--NAPA 1064
--Baldwin B179
--Wix 51064
Fuel System:
-Primary Filter:
--10 Micron RACOR 2010TMOR (blue)
--Old style Groco Filter uses GF-376 for its media.
-Secondary Filter:
--Universal 298854
--**Wix 33390 Spin-On Fuel Filter
--Car quest-86390
--Kubota 70000-43081
--Napa 3390
--Ac tp807
--Purolator PER-262-F
--Motorcraft FG72
--Fram P-7514
--Big-A 538
Injectors: Nippon Denso 093500-1560 (1570)
Accessory System:
-Fan (V) belts:
--**W/New Bracket: use 38 inch belt ½ inch width
--Universal 302238
-Old bracket use:
--Gates 7410, Dayco 15410, Goodyear 13411, Flag 41013, Car quest xl 7390
Lee’s Auto 11a0990, inside ribs 25/64" x 39 5/8" Gates 3vx400 (1/2") (inside
ribs) Dayco 15390
-**Serpentine Belt Set: Jason 10rib, 40 inch (electromaax has them in stock.)
Breather intake filter components:
-Universal #302181 includes foam filter and alum honeycomb mesh #301049 is the
filter media alone.
-**K&N RU-2450 Universal Rubber Filter
Starters:
-UNIVERSAL MARINE: 299512, 301295
-API MARINE: 17051
-KUBOTA: 15231-63012, 15231-63013, 15231-63014, 15231-63015, 15231-63016, -15271-63C13, 16097-61361, 19293-63011, E7199-63010
-**NIPPONDENSO: 028000-7460, 028000-7461, 028000-7462, **028000-7470, 028000-7471, 028000-7472, 028000-9570
-PRESTOLITE SALES: 20513040
Dan
Cooling System:
Pencil Zinc
1.5 inch length)
Oil System:
--Motorcraft FL-799
--AC PF-57
--Lee LF-2808
--NAPA 1064
--Baldwin B179
--Wix 51064
Fuel System:
-Primary Filter:
-Secondary Filter:
--Universal 298854
--Car quest-86390
--Napa 3390
--Ac tp807
--Motorcraft FG72
--Fram P-7514
--Big-A 538
Accessory System:
-Fan (V) belts:
--Universal 302238
-Old bracket use:
ribs) Dayco 15390
filter media alone.
Starters:
-API MARINE: 17051
