Universal M25 rebuild references?
Steve
Has anyone had experience rebuilding a Universal M25 deisel (vintage ~1985) on a C30? I need a recommendation for a step-by-step book or process that describes (with pictures) how to remove and disassemble/reassemble this engine for a rebuild. The manufacturer's parts, owner's, and service manuals do not contain step-by-step procedures, only parts lists and routine maintenance descriptions. Thanks, Steve
Denny Fegan
Engine Rebuilding Know How
Steve, There are lots of good books on how to rebuild diesel engines. I have the same engine in my Catalina 30 and have had to rebuild the injector and raw water pumps and the transmission. If you have never rebuilt an engine before I would suggest you remove it and have a local shop do the rebuild. Much cheaper then having the yard do it. If you can not remove it your self you should let the yard have the job. This is a Kobota engine and their parts book is pretty good but the Universal Book leaves alot to be desired.
