Thanks
Thanks for the reply. I won't reset the idle, adn I'll explain why. 1. On my engine, the speed control stops, on the speed control lever are wired in place after factory adjustment. They are not meant to be adjusted. 2. The loss of idle speed was relatively sudden, not gradual - meaning, its not from long term wear, but from some component or system fault.3. Peter Compton's excellent marine diesel troubleshooting manual indicates only a fuel restriction, as form clogged filters, or a faulty injector as among the probable causes of low idle. My filters are clean - less than 100 hours of running on them, with a new fuel tank and new fuel. I think I just puished an injector over hte edge. The exhaust has been somewhat sooty since I got hte boat 1.5 years ago. 4. I have no reason to believe the injectors have ever been replaced or serviced, in over 2000 hours of running time. Some suggest 800-900 hours between rebuilds, the USN does it every 1500 on continuosly run (generator) diesels. I assume intermittent running is tougher on them. So, that's my reasoning.I located NEW injectors at less than the cost of rebuilding the old ones, and assuming I got hte right part, I'll be replacing the injectors this weekend. I got the part by learing the manufacturer's part number of the injectors, and purchasing from a diesel engine parts company. I'll let you know what happens.jv
