John Visser
Coincident with a high-temperature event (clogged heat exchanger) my M25 developed a lower idle speed, 600 RPM rather than the usual 700. Runs rough and shaky at 600. I don't think the temp ever went near dangerous, so I'm thinking this might be unrelated. I consulted a troubleshooting book, and the engine manual, and conclude that I must have a worn-out or bad injector. The transom usually collects a sooty coat in use, since I've had the boat (1.5 years). I have no reason to believe hte injectors have ever been replaced or serviced. Total time 2000+ hours. If an injector needs service, they probably all do, is my thinking. Comments?Thanks,jv
