So, if you've done your own oil changes you are aware that the oil drain hose is not located at the lowest point of the oil pan. With the engine tilting aft on it's mounts, and this angle exacerbated when on the hard, there will always be old contaminates in that low area.
With this I'm mind, my inquiry is: Have any of you contemplated the removal of your oil pan to have it modified by a machine shop where they would drill a hole and weld on a nut that would match up to the drain hose mounted forward ?
Thanks,
Rick
~~(\_~~
Thanks,
Rick
~~(\_~~
