MarcP
Took our maiden sail on our 85 Cat 30 Tall Rig. On the way out my wife said she could smell something burning in the engine compartment. I took a look and thought it was just some residual oil on the engine. The temp gauge came up to 170 and was steady. We were only doing 2300RPM.On the way back in the same smell was there and after 5 minutes there were waves of heat some light steam and some light burnt oil vapors coming from the engine compartment. The entire compartment was very hot and obviously something was wrong. The temp gauge again only came up to 170 and we were doing ~ 2300 RPM. We had plenty of seawater going through the system. I checked the rediator expansion tank which was near over flowing and noticed that the cap was missing. I know we started with the level in the middle of the band but I do not remember if the cap was on.About 50 ft from the slip we got an intermittant alarm from the engine instrumnet panel and about a 2 minutes later the engine stalled. It turned over very slugishly and would not restart. Luckily we were close enogh to throw a line to some folks who helped pull us in the last few feet. Vaapors and heat were still coming from the engine compartment and it had that "Overheating smell"After the engine cooled down I checked the expansion tank again and it was empty. Still no cap. I put in some 50/50 antifreeze and water and the engine started up fine. We idled it for about 15 minutes but did not load it up. Temp gague was barely off of the peg.Not exactly sure what is going on and my wife wants me to have the yard check it out before she comes out.Can anyone think of what is happening with the engine? Can it be the missing cap on the expansion tank. and could the temp gague be reading wrong? What should I do next?ThanksMarcP
