Universal M-18 Oil system
408
Catalina 27 Titusville, FL
Got three quick questions.
The stock oil pressure sender on the M-18, I take it it only works the buzzer and will not drive an actual oil pressure gauge? I took the chance and hooked it to an oil pressure gauge and it pegged the gauge on the high side.
Is there a place that an oil temp gauge sender can be installed?
I have a slight rattling coming from the engine at idle, I am thinking water pump?
Thoughts?
Jun 11, 2004
1,862
Oday 31 Redondo Beach
The stock oil pressure sender on the M-18, I take it it only works the buzzer and will not drive an actual oil pressure gage? I took the chance and hooked it to an oil pressure gage and it pegged the gage on the high side.
I got a short hose with appropriate fittings on it and screwed one end into the hole in the block where the oil pressure sender goes. I put a T on the other end and screwed in the pressure sender on one side and a real pressure gage on the other side. I have to look in the engine compartment to see the actual pressure on the gage but both work fine.
Is there a place that an oil temp gage sender can be installed?
Don't know
Sorry, could be lots of things.
quote]
Aug 27, 2011
408
Figured as much on the rattle issue.
As for the oil pressure, I will do what you did. Sounds like a great idea. I already have the gauge wired in, so I will add the appropriate sender to the mix. That way I will have both the buzzer and a proper sender for the oil pressure gauge.
Thanks!
