Mel Torres
I just bought a 1980 Catalina 30, hull #1987. It has a universal diesel model #5411 11 hp. It's been running a little hot 165-180 degrees. The manuel calls for an operating temp of between 135-155 degrees.I've replaced the thermistat and water pump assemably. I've even gone as far as removeing the exhaust manifold to check for salt and carbon build-up (checked out ok). But the exhaust pipe leading from the manifold to the aqua lift muffler was totaly loaded with salt and carbon deposits! A quick trip to the plumbing shop took care of that problem. I reassembled everything and to my dismay it still is over heating! What gives? I've been told to flush the engine block with a solution of 50/50 muriatic acid and water. Any comments on the acid treatment? Is there any thing I'm missing? Any help would be very helpful. Thanks in advancemelOne more thing. there does'nt seem to be very much water coming from the engine exhuast port on the transom. I've been told that this is typical of the 5411 universal diesel. Any comments? Thanks AgainMel
