N
Nice N Easy
I have a problem concerning a Universal Diesel, model 5416, a little two cylinder model. The raw water pump bolts on the the front of the injector pump, and is mechanically driven from there. The impellar is an inch or so in front of the injector pump, mounted on a little round casting. I need to know where the seal is with this arrangement. Is it directly behind the impellar, or is it at the back side of the casting where it bolts to the injector pump body. Or both. I have a tiny water leak, at the gasket where the raw water pump bolts up to the injector pump body. As I am in an area where any parts are going to be difficult at best to come by, I am worried about water getting into the oil. The leak is not enough to worry about for the time being, if I can be reasonably sure the water will not also get into the engine oil. If anyone is familiar with this engine and knows where the seal is, please respond to this inquiry. Any and all help and suggestions will be greatly appreciated.
