Been running the m-18 for 4 years. Never a single issue. 1984 motor, original. 1200 hours approx.
Water coolant pump failed today. Has never leaked. Preflight inspection tight belt no leaks good oil the works. Motored an hour came in hit the slip and the motor quit at idle with a thunk.
Tied up , opened the engine room started the motor and it was making abnormal noise. Looked in and saw water pump hub wobbling like mad. And making the noise. Shut her down immediate. Coolant everywhere including drooling onto the belt at the crank pulley. Also burned belt bits and coolant in streaks on the engine room walls.
Looks like a pump failure. But what's with the wobbling?
Is this a normal failure?
