Universal 5411
Sean F
The base of the Sherwood Water Pump has two weeping holes. When I run the engine water flows through the lower weeping hole. What can I do or replace to stop this? I'm not getting water into the engine but by bilge pump is getting a work out.
May 10, 2006
24
Catalina 30 Ventura CA
Had it happen to me
My water pump did the same and started corroding the front of the block and foward motor mount. It still cooled though. I took the water pump off and took it apart and was going to replace the seal on the back side of the impeller. I noticed that the shaft was badly worn so I replaced the whole pump.The parts were expensive by themselves so I opted to by a new pump and it has been serving me well. The moral is if take the pump apart and find alot of worn out parts then just replace the pump , but if you can get away with it you could change the shaft seal, the cover seal and the pump to block seal and it will work. Also check the impeller for wear or flat marks on ends of the rubber tips. If worn you can be cheap and flip over the impeller or just replace that while your there. Hope this helps, John
Sean F
Thanks
Thanks John. I've got the seals on order as I replaced everything else. Hopefully this works. Sean
