Todd Osborne
Anyone had problems with their thermostat? My raw water cooled engine is running hot (180F) but remains steady at that temp. I put a water strainer with see through port just prior to the water pump. There is plenty of water flow through the system, although very little comes out the exhaust. I also backflushed the through hull valve intake & it seems fine. So all I can figure is either the thermostat is bad or my engine temp sensor is bad.
