My freshwater Catalina 27 began overheating after owning it for a year. I replaced the impeller, which had lost part od several vanes. It was still overheating after replacement. I then flushed the system out with a garden hose and spray nozzle with the thermo stat in place. There didn't appear to be any major blockages. I also closed off the seacock on the supply and witnessed water coming out of the exhaust. I then removed the thermostat and noted some small "bb" sized pieces of rubber in the seat of the thermostat. I removed the particles and flushed again, and back-flushed as well with the thermostat in place, and with the seacock both open and closed. My pump pressure is fine, there are no obstructions except that I suspect that the thermostat is not able to fully close, so I have ordered a new thermostat. Can I crimp the return line to force the pump to use lake water for cooling as a temporary measure until my new thermostat arrives? I have seen this on several posts. This is a raw water system, used on a lake, with a 140 degree thermostat.
