5411 exhaust
This is the skinny: The pipe is, if I remember correctly, one-and-a-quarter inch black iron, and is assembled using common sizes of elbows and threaded nipples, available at pretty much any hardware store. If you can reuse the manifold and the piece of brass pipe that has the water injection tube, it's pretty simple to take the black iron pieces to the store and match them up. Reassemble loosely, put in place, tighten where you can, use some exhaust bandage tape if you need it on the connections that couldn't be tightened fully, and you're done. The insulating wrap is nice, but not strictly necessary, since it tends to hide corrosion. The pipe doesn't get all that hot. Don't buy it from Catalina Direct, you'll pay a hundred bucks for ten dollars worth of pipe and it won't fit any better than you can do.
