So I just purchased a Catalina 30 with a Universal 25MXP.
Right off the bat I messed up. My first day I forgot to open the engine through hull. I ran it for about 20 to 30 minutes like that. I didn’t see any glaring issues after that but later that day I did find a fuel leak at the RACOR fuel filter housing.
So I replaced the fuel filter housing and new filter, bled the system and everything seemed fine after that.
I ran the motor at about 2100 RPMs for about 3 hours straight and then stopped to take a break. Upon continuing I noticed that the engine would not go higher than 2200 rpms. Prior to this I know it would easily run in the normal range up to 3000 rpm or so. When I got to the dock I changed the oil and replaced the impeller. (Even though the impeller wasn’t damaged at all.) and still the engine won’t go over 2200.
The previous owner stated that he typically only ran the motor at no more than 1800 rpms.
Its been my understanding that 2100 is a pretty good starting point for motoring. But the engine starts right up and seems to run fine, no thick white smoke out the back. I also checked the throttle cable and it doesnt seem to be hung up or jammed. So I’m at a loss, any ideas?
