Universal 25 Overhaul
Jul 15, 2022
2
Catalina Catalina 30 Okoboji, IA
Can anyone provide insight into the cost of an overhaul for a Universal 25? Has anyone removed the engine and completed an overhaul themselves? Was it difficult? I'm trying to run a cost/benefit on keeping my C30 which needs an overhaul or selling/upgrading to a slightly larger boat. The long pole in the tent is the engine overhaul or potential remanufacture. Thanks for you help?
Nov 6, 2006
10,131
Really depends on what is actually wrong with the engine. If it is just bearings, seals, piston rings and a valve job, probably around less than $1000 (400-500 if you do it yourself) .. I think that it is a marinized Kubota engine, so the basic parts can be had from a Kubota tractor parts supplier. Why is he overhaul necessary?
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
This^^^.
Is it top end troubles, lower end, low oil pressure, smoking, etc.? Or, does it just need "refurbishment," due to years of lack or attention, or perhaps corrosion?
I had an M25 in a C36 for 17 years. One year I took the engine home because it had broken a couple of output damper bolts. That winter I decarbonized the heads, new head gasket, adjusted the valves, removed all signs of corrosion, painted it, new hoses, new injectors, tweaked several things, new motor mounts, and put it back in. This was not so bad. Worked great.
If you need a real rebuild, like crank bearings, rings, valves, etc., you're probably better off looking to repower with a Beta or some such replacement.
That said, a newer, bigger boat would be nice! :)
Likes: Stu Jackson
Engines 101 - The BIGGEST & BEST collection of M25 Series Universal Engine Information on the Internet, plus some M35, too :) This includes a link to the Critical Upgrades topic which has more engine information please read it too.
Diesel Engine - c34.org
One of the posts in that wiki is this one:
Rebuilding a M25xp by Dave Sanner
Good luck. It always helps to define the issue(s) before you go tearing into things.
Jul 15, 2022
2
This^^^.
Thanks for the info. I haven’t yet determined what it needs. Open disclosure…my expertise isn’t in diesel mechanics so I need to just take it in. My father is a gear head and needs a mechanical task, so I was going to suggest to him that we work on it together, so I was just inquiring about difficulty. Also, as Stu suggests, perhaps I’m just trying to justify a larger boat
