@Peggie Hall HeadMistress had recommended Uniseals to add a pump out to a portapottie. I'm in the process of adding a fill port to my fresh, flush tank on my portapottie. I have everything, including a Uniseal but noticed that the minimum tank thickness is 1/8". My blow molded tank is much thinner. Will this be an issue? I can cut out a piece of plastic as a spacer. I'm pretty confident that BedIt will work well as a seal between the two pieces of plastic. I attached a garden hose to the bottom of a 5 gallon bucket and BedIT worked well.
Note: This tank contains freshwater that is used for the head only. It's roughly 4-5 gallons so if it leaks, it's not catastrophic
