Hi all,
I wonder if I could get some suggestions regarding a problem I am having with my 2003 Volvo Penta MD2030.
Whilst on a 6 hour motor today I noticed having set the throttle at 2250 rpm every few minutes the rpm would drop to 2000 rpm then within a few seconds recover to 2250. The fluctuation was a bit more dramatic when I opened and set the throttle to 2500 rpm.
When set at 2000 rpm the fluctuation was minimal. When I returned to the dock the engine idled normally and in natural I took the rpm to 3000 and held for a moment, again without problem, so my feeling is that this problem only occurs under load.
The engine makes no smoke and apart from this issue appears totally normal. I did notice a little vibration on approach but this went when I nudged the throttle a little.
Both filters were replaced 60 hours ago back in May this year.
Any suggestions would be greatly appreciated.
