P
Paul Meyer
When my Catalina 27 is underway, by sail or motor, it tends to squat such that the exhaust outlet on the transom is under water. According to standard sources such as Vetus, Centek, and Nigel Calder, the base of the outlet should be 2-3 inches above the waterline. (I wonder if Catalina designed it that way as a means for low cost, mufflerless sound reduction.)I am completely rerouting the exhaust in an attempt to eliminate the possibility of a following sea filling the engine though the exhaust. I plan to do this by routing the exhaust hose 18 inches above waterline just ahead of the transom, adding a valve to the exhaust in the same area, a flapper at the exit, and a waterlift muffler.The existing system has no muffler, leaky hose, and exits straight out the transom.My question is whether my engine (Universal 5411 11hp diesel) could handle the additional back pressure of a waterlift muffler and longer, more roundabout exhaust hose routing since it already has to deal with the back pressure of the exhaust exiting the hull under water?It would be possible to raise the exhaust exit in the transom by a couple of inches - but not attractive due to all the fibreglass work that would entail. I understand that if I leave the exhaust underwater it would be a good idea to a add a high exhaust temp alarm.My real question is whether I can leave the existing underwater exhaust exit alone while also making the above changes? or do I really need to move the exit up out of the water for excess back pressure or other reasons?Paul MeyerNew Brunswick Canada
