Does anyone know what is under the floor? Has anyone removed the floor for repairs? I have noticed that my floor is very weak and finally last month, stepped through the floor. I did normal repair with fiberglass cloth and devcon, but wonder if I need to remove the entire floor and replace/rebuild what is underneath. Any suggestions? Or do I need to call Hunter?
I did work on my 170 earlier this summer to repair a motor mount and reinforce the deck on the starboard side (had the same problem as you). The cap is plastic over about 2" of high-density foam. Here's what I did to support the deck:
For the deck:
- Remove skid tape
- using a 4" hole saw, drill holes under the anti-skid area where support is needed. I used supports in 4 places, probably only needed 2 or 3. The plastic material will seperate from the foam backing, keep this for reassembly.
- Form 8" cylinders out of mylar sheets, 12" or so tall (depends where in the deck you are)
- Compress the cylinders and insert in the openings so they stand upright in the holes
- Pour 4 pound 2-part urethane foam into the holes. This will take multiple pours. The foam will be contained in the mylar cylinders and support the deck. Some will expand out of the opening, this is OK
- After setting, trim the foam to match the normal foam core. The plastic disk cut in the second step can be glued back in place
- Replace anti-skid tape over the openings to hide the repair
I have not replaced the anti-skid tape yet, have not been able to establish contact w/ Hunter for a replacement. Plenty of after-market solutions are available, however.
Works VERY well and not as hard to do as one may think. Sorry, should have taken pics. IM me for additional info, I'll shoot you a phone number if you like.
