unclogging thru hull
11
2 32 Pass Christian, MS
I have a clogged thru hull intake that cools my A.C.
Does anyone know a procedure to clear the clog other than diving under?
Thanks.
Bowie
Shell
Sep 26, 2007
138
Catalina 30 standard JC/NYC
Close the thru hull.
Disconnect the hose from it.
Get a garden hose and connect it to the thru hull.
Use a wet rag to make a seal.
open through hull.
Let the pressure from the garden hose blow out the clog.
It can get a little wet bt you won't sink.
Good luck.
Shell
Mar 16, 2009
11
Thanks. I tried that once, without the rag as a seal. I will try again.
I might try reversing the situation by doing the same attempt with a
manual bilge pump....kind of a plunger effect.
I have a small stream, about the size of a straw coming through without much pressure.
Should'nt the hose be flowing a full hose sized stream? Therefore, the intake water flow would
be my problem, not my pump? Correct?
Thanks.
Bowie
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
You might try using a portable air compressor to blow it out. Make a good seal with a wet rag around the air nozzle and that might clear it.
